Denverrose3
Jun 09, 2023Follower
Cm1200 won't connect with my NH app?
So i am trying to check for a firmware update- cause its been a bit since it did one. We moved and got a new provider- app stopped working. Just had to RESET my admin passwords and such again. Did a ...
Jun 11, 2023Guru - Experienced User
Be sure you contact your ISP to help and information on getting the modem connected to there services. They have to be the ones to get it working on there network.
Denverrose3 wrote:
So i am trying to check for a firmware update- cause its been a bit since it did one. We moved and got a new provider- app stopped working. Just had to RESET my admin passwords and such again. Did a reset, no change. Keeps saying my box can't be reached. I've tried it from the computer side as well to see if I could 'force' an update there was none to be had for it. I'm out of ideas on what's wrong. I've even uninstalled the app and cleared the cashe.
Denverrose3
