NotWIFIWizard
Oct 08, 2024Follower
CM1200 Won't Sync to Linksys Velop Mesh MX6200
New mesh system, at 6 months I started to have an issue with my mesh system disconnecting from my modem. For weeks now, it will not connect at all, it cycles like it is connecting then powers off. Th...
Oct 08, 2024Guru - Experienced User
Only thing would be to make sure your connecting the external router system to WAN Port #1 on the back of the CM1200 modem. That should be the primary ISP WAN servicing port. ALL other ports will not be usable since those ports require WAN IP address assignment from the ISP and which most ISPs only give out one WAN IP address per household and per one modem.
Be sure your using good quality LAN cable between the modem and router system. CAT6 is recommended.
Contact Linksys for help and support informatoin regarding there product.
