Original post didn't come out right
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 675000000 Hz | Locked | | Connectivity State | OK | Operational | | Boot State | OK | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | IPv6 only |
| Downstream Bonded Channels (Partial Service) |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables | | 1 | Locked | QAM256 | 44 | 675000000 Hz | -5.7 dBmV | 41.3 dB | 0 | 0 | | 2 | Locked | QAM256 | 13 | 489000000 Hz | -4.6 dBmV | 42.7 dB | 0 | 0 | | 3 | Locked | QAM256 | 14 | 495000000 Hz | -4.6 dBmV | 42.7 dB | 0 | 0 | | 4 | Locked | QAM256 | 15 | 501000000 Hz | -4.8 dBmV | 28.7 dB | 207449 | 0 | | 5 | Not Locked | Unknown | 16 | 507000000 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | | 6 | Locked | QAM256 | 17 | 513000000 Hz | -5.2 dBmV | 32.2 dB | 1614112 | 303930 | | 7 | Locked | QAM256 | 18 | 519000000 Hz | -5.4 dBmV | 36.4 dB | 0 | 0 | | 8 | Locked | QAM256 | 19 | 525000000 Hz | -5.4 dBmV | 37.7 dB | 0 | 0 | | 9 | Locked | QAM256 | 20 | 531000000 Hz | -5.4 dBmV | 41.0 dB | 0 | 0 | | 10 | Locked | QAM256 | 21 | 537000000 Hz | -5.2 dBmV | 41.6 dB | 0 | 0 | | 11 | Locked | QAM256 | 22 | 543000000 Hz | -5.0 dBmV | 42.4 dB | 0 | 0 | | 12 | Locked | QAM256 | 23 | 549000000 Hz | -4.9 dBmV | 42.5 dB | 0 | 0 | | 13 | Locked | QAM256 | 24 | 555000000 Hz | -4.9 dBmV | 42.3 dB | 0 | 0 | | 14 | Locked | QAM256 | 25 | 561000000 Hz | -5.0 dBmV | 42.1 dB | 0 | 0 | | 15 | Locked | QAM256 | 26 | 567000000 Hz | -5.0 dBmV | 41.9 dB | 0 | 0 | | 16 | Locked | QAM256 | 27 | 573000000 Hz | -5.2 dBmV | 41.9 dB | 0 | 0 | | 17 | Locked | QAM256 | 28 | 579000000 Hz | -5.3 dBmV | 41.9 dB | 0 | 0 | | 18 | Locked | QAM256 | 29 | 585000000 Hz | -5.4 dBmV | 42.0 dB | 0 | 0 | | 19 | Locked | QAM256 | 30 | 591000000 Hz | -5.4 dBmV | 42.0 dB | 0 | 0 | | 20 | Locked | QAM256 | 31 | 597000000 Hz | -5.5 dBmV | 39.1 dB | 0 | 0 | | 21 | Locked | QAM256 | 32 | 603000000 Hz | -5.5 dBmV | 29.1 dB | 227893 | 0 | | 22 | Locked | QAM256 | 33 | 609000000 Hz | -5.7 dBmV | 37.3 dB | 0 | 0 | | 23 | Locked | QAM256 | 34 | 615000000 Hz | -5.7 dBmV | 41.8 dB | 0 | 0 | | 24 | Locked | QAM256 | 35 | 621000000 Hz | -5.7 dBmV | 41.7 dB | 0 | 0 | | 25 | Locked | QAM256 | 36 | 627000000 Hz | -5.8 dBmV | 41.5 dB | 0 | 0 | | 26 | Locked | QAM256 | 37 | 633000000 Hz | -5.8 dBmV | 41.2 dB | 0 | 0 | | 27 | Locked | QAM256 | 38 | 639000000 Hz | -5.9 dBmV | 41.7 dB | 0 | 0 | | 28 | Locked | QAM256 | 39 | 645000000 Hz | -5.8 dBmV | 41.8 dB | 0 | 0 | | 29 | Locked | QAM256 | 40 | 651000000 Hz | -6.0 dBmV | 41.7 dB | 0 | 0 | | 30 | Locked | QAM256 | 41 | 657000000 Hz | -5.8 dBmV | 41.8 dB | 0 | 0 | | 31 | Locked | QAM256 | 42 | 663000000 Hz | -5.8 dBmV | 41.8 dB | 0 | 0 | | 32 | Locked | QAM256 | 43 | 669000000 Hz | -5.9 dBmV | 41.7 dB | 0 | 0 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 4 | 5120 Ksym/sec | 35600000 Hz | 53.0 dBmV | | 2 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV | | 3 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV | | 4 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV | | 5 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV | | 6 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV | | 7 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV | | 8 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| Downstream OFDM Channels |
| Channel | Lock Status | Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords | | 1 | Locked | 0 ,1 ,2 ,3 | 193 | 957000000 Hz | -8.72 dBmV | 38.1 dB | 148 ~ 3947 | 86779531 | 58860179 | 954 | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 4095 | 0 | 0 | 0 |
| Upstream OFDMA Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | | 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
| Extended Upstream Transmit Power |
| Current System Time:Tue May 09 23:12:24 2023 |
| System Up Time:01:29:57 |
