chucktalk's avatar
chucktalk
Follower
Oct 18, 2021
CM2000 - very pleased with the product, it just works as it should
I have a very specific deesign to my network, where I use a Firewalla for the router and Orbi system acts as an AP. Allows for finer grained controls on access and geo-fencing my network. Bought some very well-known manufacturers modems based on a recommendation from an ISP Tech . 32x4 Docsis 3.1 and they dropped connections 3 to 4 times a day. Replace them with Nighthawl CM2000 32x8 Docsis 3.1 and no issues now for weeks. Never again will I mpass up the Netgear modems -they just work.
Wanted to say thanks, as I don't know where I can, but it makes a huge difference for me.
  • Glad to see a positive report on here! Usually we only see the negatives!
    Let us know if you do run into issues and we'll do our best to help
1 Reply
  • plemans's avatar
