lostdoc's avatar
lostdoc
Guide
Apr 26, 2022
CM2000 all lights flashing, no internet
I am in a similar boat - the second time in 8 months that the device has completely bricked. I dont understand what on earth I am doing wrong - they are in a totall open ventilated space, connected to a surge protected socket. I moved sockets to accomodate a new plug and it bricked it. I am on the phone with customer support again despite telling them I have gone through this. I will try one final time (though I will refuse to pay for a replacement) and if not, will try to seek a refund via my credit card company. Absolutely absurd.
  • Keep at them - I think they know it’s a problem so they may extend a replacement. Otherwise, should try to see if your credit card (if you paid that way) can do chargebacks…
    • Jmcieri's avatar
      Jmcieri
      Tutor
      They won’t extend a replacement but the credit card thing may work. Thanks.
  • FURRYe38's avatar
    Were you able to get in contact with NG support and check on a RMA?
    • lostdoc's avatar
      lostdoc
      Guide
      This is the second CM2000 in 8 months of owning them that I have had the device 'brick'. All lights are flashing white and all I did was move the plug to a different socket. Its unbelievable. I am going to see if a third device works if not, I am going to try to see if I can claim back via Amex.
