Patryn
Feb 18, 2024Aspirant
CM2000 compatibility with TP-Link router
I am looking at buying my own cable modem for use with my Astound/RCN service. I currently have 1gig service, with an option to upgrade to 1.5gig. My router is a TP-Link AXE7800. When I had my cu...
Kitsap
Feb 18, 2024Master
Patryn wrote:I am looking at buying my own cable modem for use with my Astound/RCN service. I currently have 1gig service, with an option to upgrade to 1.5gig. My router is a TP-Link AXE7800. When I had my current modem installed (RCN owned Arris cable modem, very outdated) I asked the technician what brand would be recommended. He told me that Netgear and TP-Link products don't work well together and to avoid them, but I haven't been able to find much to support his statement.
So I'm wondering if there would be any issues running the above wi-fi router with a Netgear CM2000 cable modem. The other option I have been looking at is the Arris S33 but the heat issues I see mentioned so often are very worrying. The CM2000 would be my first choice if there is no compatibility issues.
Thank you.
Your first step is to make certain the CM2000 is on the Astound/RCN list of approved/supported modems.
There should be some user forums with more specific and broader based information than from your install field technician. Maybe try here: https://www.dslreports.com/forum/rcn
From a hardware standpoint, the CM2000 is a DOCSIS 3.1 certified modem and it has a 2.5 Gbps output port. Both will provide you with years of service without going out of date.
- PatrynFeb 18, 2024Aspirant
The CM2000 is on the small sample list of approved modems. My router also has a 2.5 Gbps port so that's a plus.
I will look at the forum you linked, also.- KitsapFeb 18, 2024Master
There is a TP Link Home Network Community forum here: https://community.tp-link.com/us/home/forum/2414
- plemansFeb 19, 2024Guru - Experienced User
Kitsap is exactly correct at directing you.
From my experience, I haven't had any issues between tp-link and netgear. I don't have that specific router (and I doubt the tech did either) but none of mine had been an issue.
You should be able to use pretty much any router with the cm2000 (if cm2000 is compatible with your service).
- KitsapFeb 19, 2024Master
Whatever your modem choice, make sure you get a good quality Ethernet cable to connect between the modem and router. Currently available from Amazon, a shielded twisted pair (STP) Cat 6A would work well.
