Wonderbread1127
Sep 25, 2022Aspirant
CM2000 DOCSIS compatibility
I currently have a CM1000 which is Docsis 3.0 and 3.1 compatible. I've been having issues with my internet and my provider said for some reason it connects to the 3.1 hub and speeds are fine but then ...
Kitsap
Sep 25, 2022Master
By specification, DOSCIS 3.1 is backward compatible with DOSCIS 3.0. No such thing as a DOSCIS 3.1 only modem.
I think your provider was feeding you a line.
You are mixed up with your terminology. Both the CM1000 and the CM2000 devices are cable modems only. They have no capability to function as a router. You would need to connect a router downstream of either modem.
- Wonderbread1127Sep 25, 2022AspirantYeah that was the conclusion I was coming to after reading more online regarding 3.0 and 3.1.
And yes I know the difference between a router and modem. There was no drop down tab available for "modems" just routers- Wonderbread1127Sep 25, 2022AspirantI see I wrote router in my initial post. Yes this is all regarding my modem.
- KitsapSep 25, 2022Master
Wonderbread1127 wrote:
I see I wrote router in my initial post. Yes this is all regarding my modem.Copy and paste the values from your cable connection page on your modem. This will show your power levels and other details.
Review your cable modem event log to see if there are any warning or critical level events logged when you are having issues.
- michaelkenwardSep 26, 2022Guru - Experienced User
There was no drop down tab available for "modems" just routersI don't know where this drop down was, but it might have been different had you started your conversation in the appropriate section:
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware.
