Old_Soldier
Mar 16, 2024Apprentice
CM2000 event log
Only showing these eight entries, in the event log and the top one gets overwritten 2-3x a day. Anyone have any ideas? Time Priority Description Sat Mar 16 05:20:47 2024 (Warn...
Mar 16, 2024Guru - Experienced User
got a copy of the screensnip of the cable connections page?
From the event log, your power level is going out of optimal range and then having signal issues back to the isp.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Old_Soldier
Cable status shows as good. CM, downstream and upstream show green.
