Benny1053
Mar 22, 2022Tutor
CM2000 Fails to Activate - Xfinity
Model wouldn't let me select CM2000, unsure why but to the story.... I purchased a CM2000 back in December and started having issues with it in February, after ISP came out and checked the lin...
Mar 22, 2022Guru - Experienced User
Event logs might help as well as the cable connections page.
- Benny1053Mar 22, 2022Tutor
I'll work on these this evening, I'll have to switch back to the CM2000 to get the logs. Thanks for the quick response!
Cable Connection
Cancel Apply
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
0
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 507000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 5 507000000 Hz 6.8 dBmV 41.3 dB 0 0
2 Locked QAM256 2 489000000 Hz 7.4 dBmV 41.5 dB 0 0
3 Locked QAM256 3 495000000 Hz 7.3 dBmV 41.4 dB 0 0
4 Locked QAM256 4 501000000 Hz 7.0 dBmV 41.3 dB 0 0
5 Locked QAM256 6 513000000 Hz 6.8 dBmV 41.3 dB 0 0
6 Locked QAM256 7 519000000 Hz 6.5 dBmV 41.0 dB 0 0
7 Locked QAM256 8 525000000 Hz 6.3 dBmV 40.8 dB 0 0
8 Locked QAM256 9 531000000 Hz 6.4 dBmV 41.0 dB 0 0
9 Locked QAM256 10 537000000 Hz 6.2 dBmV 41.0 dB 0 0
10 Locked QAM256 11 543000000 Hz 6.0 dBmV 40.9 dB 0 0
11 Locked QAM256 12 549000000 Hz 6.0 dBmV 40.8 dB 0 0
12 Locked QAM256 13 555000000 Hz 6.2 dBmV 40.8 dB 0 0
13 Locked QAM256 14 561000000 Hz 6.1 dBmV 40.8 dB 0 0
14 Locked QAM256 15 567000000 Hz 5.8 dBmV 40.7 dB 0 0
15 Locked QAM256 16 573000000 Hz 5.7 dBmV 40.5 dB 0 0
16 Locked QAM256 17 579000000 Hz 5.7 dBmV 40.4 dB 0 0
17 Locked QAM256 18 585000000 Hz 5.8 dBmV 40.4 dB 0 0
18 Locked QAM256 19 591000000 Hz 5.7 dBmV 40.5 dB 0 0
19 Locked QAM256 20 597000000 Hz 5.6 dBmV 40.5 dB 0 0
20 Locked QAM256 21 603000000 Hz 5.6 dBmV 40.4 dB 0 0
21 Locked QAM256 22 609000000 Hz 5.8 dBmV 40.4 dB 0 0
22 Locked QAM256 23 615000000 Hz 5.9 dBmV 40.4 dB 0 0
23 Locked QAM256 24 621000000 Hz 6.0 dBmV 40.5 dB 0 0
24 Locked QAM256 25 627000000 Hz 5.8 dBmV 40.4 dB 0 0
25 Locked QAM256 26 633000000 Hz 5.8 dBmV 40.3 dB 0 0
26 Locked QAM256 27 639000000 Hz 5.7 dBmV 40.2 dB 0 0
27 Locked QAM256 28 645000000 Hz 5.7 dBmV 40.3 dB 0 0
28 Locked QAM256 30 651000000 Hz 5.5 dBmV 40.3 dB 0 0
29 Locked QAM256 31 657000000 Hz 5.4 dBmV 40.2 dB 0 0
30 Locked QAM256 32 663000000 Hz 4.9 dBmV 39.9 dB 0 0
31 Locked QAM256 33 669000000 Hz 4.7 dBmV 39.8 dB 0 0
32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 5 5120 35600000 Hz 34.3 dBmV
2 Locked ATDMA 6 5120 29200000 Hz 34.5 dBmV
3 Locked ATDMA 7 5120 22800000 Hz 34.3 dBmV
4 Locked ATDMA 8 5120 16400000 Hz 34.0 dBmV
5 Locked ATDMA 10 1280 39600000 Hz 34.5 dBmV
6 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
Downstream OFDM Channels
Channel Lock
Status Modulation /
Profile ID Channel
ID Frequency Power SNR /
MER Active Subcarrier
Number Range Unerrored
Codewords Correctable
Codewords Uncorrectable
Codewords
1 Locked 0 ,1 ,2 ,3 37 690000000 Hz 4.8 dBmV 39.3 dB 1108 ~ 2987 174627 174549 0
2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1 Not Locked 0 0 0 Hz 0 dBmV
Extended Upstream Transmit Power
Current System Time:Tue Mar 22 15:43:12 2022
System Up Time:00:00:54
Help CenterShow/Hide Help CenterEvent Log
Clear Log Refresh
Time Priority Description
Tue Mar 22 15:43:00 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 22 15:42:55 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6
Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 22 15:12:25 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 22 15:12:20 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 20:13:16 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 20:13:11 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Time Not Established (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 20:01:47 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 20:01:42 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:53:30 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:53:25 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:50:22 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:50:17 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:48:23 2022 (Warning (5)) MDD message timeout;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:48:23 2022 (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:47:42 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:47:37 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:43:18 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:43:13 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Mon Mar 21 19:27:41 2022 (Warning (5)) Dynamic Range Window violation
Mon Mar 21 19:27:41 2022 (Warning (5)) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
Help CenterShow/Hide Help Center - Benny1053Mar 28, 2022Tutor
Is there anything in the logs that seem unusual?
- plemansMar 28, 2022Guru - Experienced User
tougher to read when you post them like that.
Take a screen snip of them. Its easier to read/layout.
- FURRYe38Mar 28, 2022Guru - Experienced User
The power levels on the up are a bit high.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
There a some criticals seen in the event logs that the ISP should look into.
https://highspeed.tips/docsis-events/
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
If the ISP can't seem to get the modem online, you might need to rent one of there for short term use to see if there's connects.
Is the CM2000 new? If so, might return it and get another to see if the 2nd one works...
downstream power levels are fine.
upstream is low but that could be the OP is closer to the hub.
Plus hard to read because the uptime is only showing 54 minutes and its formatted poorly.
Use the modem for a while. Then get the logs/cable connections page. that'll show if theres issues on specific channels/logs.
