Benny1053
Mar 22, 2022Tutor
CM2000 Fails to Activate - Xfinity
Mar 22, 2022Guru - Experienced User
well that tells us nothing.
Did you contact xfinity?
What reason do they give for it not activating?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
Benny1053
Mar 22, 2022Tutor
sorry when I was trying to post on the other topic this topic generated and im not sure how to delete it.
