dman97
Nov 29, 2021Tutor
CM2000 Flashing Upstream Light
I just installed a CM2000 modem and the upstream light is constatnly flashing. It is working fine, I am getting my plan speeds (900/20 Mbps). Is this something I should to contact Xfinity about...
dman97
Nov 30, 2021Tutor
Is the ISP service box where the cable enters my house? I have a MoCA splitter there with a POE filter. Would that be the cause of the errors?
Nov 30, 2021Guru - Experienced User
Could be. A test you can try, temporarily remove this connector and directly connect the cable to the other side for a more direct connection with the modem. See if the Uplink LED continues to blink or not.
