trob787
Nov 25, 2020Aspirant
CM2000 keeps losing downstream connection.
Hi all, Having a sporadic issue with my new Netgear CM2000 modem. I keep losing the downstream connection, or so it seems, the LED blinks and I have no connectivity. Rebooting the modem fixes the...
Nov 25, 2020Guru - Experienced User
Photos can take a while because a moderator has to approve them. And unless there's a new reply, its rare for us to re-check posts.
So you can click on "choose file" and attach the photos (each one an individual post) and we can view them. Otherwise it could be a while.
But FURRYe38 advice is sound as well
- trob787Nov 25, 2020Aspirant
plemans wrote:Photos can take a while because a moderator has to approve them. And unless there's a new reply, its rare for us to re-check posts.
So you can click on "choose file" and attach the photos (each one an individual post) and we can view them. Otherwise it could be a while.But FURRYe38 advice is sound as well
Thanks! Will attach as separate posts.
