HGinDC
Jul 05, 2021Guide
CM2000 Modem: blinking downstream light
Hello. I am using a Nighthawk CM2000 router (which, BTW, is not a listed model for the model dropdown) connected to a Nighthawk AX4 router. Periodically the downstream light on the modem starts blink...
Jul 06, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- HGinDCJul 06, 2021Guide
Thank you for the response. Below is a copy of the "modem event log." Is this the info you requested? I have been often in touch with RCN and the modem has been "reprovisioned" several times. Also, I have had (and paid for) three service calls. This first time the tech replaced the connectors at the ends of the cable, and removed one splitter her found in the line. The subsequent visits found the signal to be within spec, and the tech stated that since I had my own modem that was all they could do since they did not support customer-owned modems.
Tue Jul 06 06:09:00 2021 (Error (4)) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Mon Jul 05 01:45:51 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Mon Jul 05 01:45:26 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Mon Jul 05 01:21:01 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Mon Jul 05 01:20:36 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jul 02 18:09:00 2021 (Error (4)) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jul 02 09:17:21 2021 (Critical (3)) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 29 06:09:00 2021 (Error (4)) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Sat Jun 26 23:09:53 2021 (Critical (3)) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:08 2021 (Warning (5)) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:06 2021 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Error (4)) Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 18:09:01 2021 (Warning (5)) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv4
Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Fri Jun 25 09:41:52 2021 (Error (4)) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:50:57 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:50:32 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:50:24 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:49:39 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:48:08 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:45:39 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:44:13 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:43:31 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:19:00 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:18:33 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:16:43 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:15:39 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:14:55 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:14:02 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;
Thu Jun 24 17:13:34 2021 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:9f:5e:a8;CMTS-MAC=00:af:1f:1f:85:5e;CM-QOS=1.1;CM-VER=3.1;- FURRYe38Jul 06, 2021Guru - Experienced User
- HGinDCJul 06, 2021GuideCable Connection
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure Procedure Status Comment Acquire Downstream Channel 603000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 10 603000000 Hz -3.2 dBmV 42.0 dB 0 0 2 Locked QAM256 1 549000000 Hz -0.8 dBmV 43.4 dB 0 0 3 Locked QAM256 2 555000000 Hz -1.7 dBmV 42.7 dB 0 0 4 Locked QAM256 3 561000000 Hz -2.8 dBmV 42.3 dB 0 0 5 Locked QAM256 4 567000000 Hz -2.7 dBmV 42.3 dB 0 0 6 Locked QAM256 5 573000000 Hz -1.1 dBmV 42.4 dB 0 0 7 Locked QAM256 6 579000000 Hz -1.1 dBmV 42.5 dB 0 0 8 Locked QAM256 7 585000000 Hz -1.2 dBmV 42.6 dB 0 0 9 Locked QAM256 8 591000000 Hz -1.9 dBmV 41.1 dB 0 0 10 Locked QAM256 9 597000000 Hz -2.1 dBmV 42.0 dB 0 0 11 Locked QAM256 11 609000000 Hz -3.0 dBmV 41.9 dB 0 0 12 Locked QAM256 12 615000000 Hz -2.3 dBmV 41.9 dB 0 0 13 Locked QAM256 13 621000000 Hz -2.8 dBmV 41.9 dB 0 0 14 Locked QAM256 14 627000000 Hz -4.0 dBmV 41.4 dB 0 0 15 Locked QAM256 15 633000000 Hz -3.3 dBmV 41.3 dB 0 0 16 Locked QAM256 16 639000000 Hz -2.6 dBmV 41.8 dB 0 0 17 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 18 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 19 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 20 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 36800000 Hz 42.8 dBmV 2 Locked ATDMA 2 5120 30350000 Hz 42.3 dBmV 3 Locked ATDMA 3 5120 23900000 Hz 41.3 dBmV 4 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 159 657000000 Hz -1.7 dBmV 41.2 dB 646 ~ 3449 63583238859 14957734007 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit Power Current System Time:Tue Jul 06 17:29:39 2021System Up Time:10 days 23:21:11
- RcanneNov 18, 2021Aspirant
I also suffer from the same situation on the Nighthawk CM2000 (Blinking downstream light,) and have tried everything that is offered to correct the problem with no results. I restart the modem and typically within days, if not hours the problem is back. The longest it has stayed solid is about a week. Like others have reported the modem seems to be functioning normally; speed is as expected. So, my question is hopefully simple to answer, should I stop concerning myself with the blinking downstream light, and just let it blink? No need to get technical please, just a straight forward "YES" or "NO" would be greatly appreciated.
- FURRYe38Nov 18, 2021Guru - Experienced User
