kerNol
Dec 03, 2022Follower
CM2000 multiple events and unicast error
So I’ve had the CM2000 in operation for about a year with no issues. My local ISP has been doing massive upgrades recently and these began, they’ve been out multiple times and can’t seem to find any a...
Dec 03, 2022Guru - Experienced User
Its much easier to read a screen snip.
Also include your cable connections page.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
