hanserya
Jun 20, 2022Tutor
CM2000 Slow Download/Upload Speeds
I recently purchased a CM2000 to replace the equipment that I was leasing from Suddenlink. The modem that they provided was testing at 900Mbps down/40Mbps up but this Nighthawk is only testing at 21....
hanserya
Jun 21, 2022Tutor
This is the first time correctables/uncorrectables has been above 0. I just tried the other modem again as well and it is still pulling top speeds while this netgear is only pulling 20-22Mbps down.
Jun 21, 2022Guru - Experienced User
You have a lot of errors in the line.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- hanseryaJun 21, 2022Tutor
Why would this modem have issues with the line when the other one does not? Is it just more touchy?
- plemansJun 21, 2022Guru - Experienced User
No idea what your other modem is but it could be a couple things.
1. the other once could be a docsis 3.0 device and the issue is on the 3.1 channels
2. it could be the other modem is starting at a difference frequency and the issues are only on a small section of frequencies. That does happen
Suddenlink doesn't push 3.1 channels to my understanding. My plan actually caps at 940-960 or something like that which should be the max for the 3.0 protocol. It's not gig speed in a literal sense like you get from Xfinity. The device is supposed to fallback to 3.0. If that's not what's happening, then the problems being on the 3.1 channels from my ISP would make sense. That would mean that they're providing incorrect information but it's not shocking given their track record so far.
