bheg
Jan 23, 2023Aspirant
CM2000 stop working all of a sudden
Hello All, I been troubleshooting my network the last 4 hours and narrow it down to the my modem (CM2000). I bought it in 2021 and looks like the one year warranty expire already, go figure...So ...
bheg
Jan 24, 2023Aspirant
Already tried that, straight lan to desktop no connection to gui even after factory reset.
Jan 24, 2023Guru - Experienced User
With the cm2000 hooked up, is the isp able to activate and see it?
Thats where I'd start. Get them able to activate it.
Once they can (if they can), let it self activate. Then power it off, give it 2 minutes, and connect the router back up to it.
then power the modem up give it 2 minutes and power the router up.
Usually if the modem lights are all on (depending on color) and solid, its still working.
- FURRYe38Jan 24, 2023Guru - Experienced User
Might check the volts and amps at the power adapter tip to be sure they are same and what's seen on the power adapter printed info as well. Try a different same volt and amp adapter to compare...
Can try a 30-30-30 and see if this "might" help, not sure if it will. đ
