kcb2627
Feb 23, 2023Aspirant
CM2000 won’t reconnect while Generac standby generator on
I can’t figure out why the modem won’t connect after power goes out and standby generator kicks on. Every single time there’s an outage the internet never connects. I even bought a sign wave ups syste...
Feb 23, 2023Guru - Experienced User
Is the device you connecting to the CM modem the only device connected?
Be aware that the CM modem is a modem only, so no wifi or router built in here. If you have more than 1 device, you'll need a external wifi router to connect to the CM modem. Then connect you devices to this wifi router.
kcb2627
Yeah, Eero Pro 3 pack
