helpplease2021
Feb 22, 2021Aspirant
CM2000/Orbi/Xfinity constantly dropping connection
(The Model question did not list CM2000, but I have a CM2000 and not the CM1200). It's been over a year now with the Internet disconnecting dozens of times, day and night. Xfinity says it's my eq...
Bloat
Feb 23, 2021Aspirant
Hi
I have a Netgear CM1200 modem Firmware 2.02.03
At the bottom of your log file there is a check box "Extended Upstream Transmit Power" that may or may not be available to you...it depends on the ISP. Make sure it is checked and reboot modem, router, it worked for me. Best of Luck.
