Kitsap
Sep 07, 2021Master
CM2050V – Admin Page Access
The CM2050V is not listed in the dropdown model list. Just replaced a Comcast XB6-A with a Netgear CM2050V. The old network had the XB6-A in bridge mode feeding a Netgear R7800. I could access ...
Sep 07, 2021Guru - Experienced User
Connect a wired PC directly to the back of the CM modem. Power it OFF and back ON for 1 minute. Afters it ready, check 192.168.100.1 on the wired PC with a web browser.
- KitsapSep 07, 2021Master
FURRYe38 wrote:Connect a wired PC directly to the back of the CM modem. Power it OFF and back ON for 1 minute. Afters it ready, check 192.168.100.1 on the wired PC with a web browser.
That is the process I used for activation. Now it is activated and connected to the R7800, I would like to access the modem admin page from a computer connected to the R7800 without rearranging cables and etc.
- FURRYe38Sep 07, 2021Guru - Experienced User
So you have access the modems web page with the direct wired PC connected to the modem? if so, and you can't with the R7800 connected, your problem would be the R7800 router.
