myobb
May 01, 2025Aspirant
CM2050V - Significant packet loss detected - Is my Cable modem failing?
It is suspected that the cable modem may be experiencing a defect and thus necessitate replacement. During the process of backing up substantial video files, ranging in size from 40GB to 80GB, to a c...
May 07, 2025Guru - Experienced User
Seeing Criticals and Warnings in the event log that the ISP needs to look at.
Have a friend, neighbor or family member that is on same ISP, or could be different cable ISP to test this unit at a remote location to see if it shows same issues and logs? One way to tell if unit could be failing, however not confident in calling the unit going bad just yet.
How long have you had the unit for?
myobb
May 07, 2025Aspirant
I bought brand new and starting using the cable modem in April 2022.
