JSchm83
Oct 12, 2020Aspirant
CM2050V + Altice with voice
Does anyone know if the CM2050V will also work on Altice? I know it says xfinity and the service is similar, just wanted to check and see if anyone knew before I pull the trigger
Oct 12, 2020Guru - Experienced User
Call the ISP first to ask abot this. They will know. I think the CM with voice is meant for CC mostly.
