CAmbr52342
Apr 11, 2021Tutor
CM2050V 2.5 Gbps Multi-Gig Connection to RAX200
Hello, I am not sure which connection I need to make on the back of my RAX200 in order to use the 2.5Gbps from the modem. Do I connect the modem to the multi-gig port on the back of the RAX200 o...
- Apr 12, 2021
Please mark your thread as solved so others will know.
Enjoy, :smileywink:
CAmbr52342 wrote:
Thank you! It works.
Apr 11, 2021Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
I would review the installation guide and user manual for the RAX200. I believe the 2.5Gb port can be used for the WAN side. You'll need to check for any configurations though.
Good Luck.
- CAmbr52342Apr 11, 2021Tutor
Thanks. I will try.
