CAmbr52342
Apr 11, 2021Tutor
CM2050V 2.5 Gbps Multi-Gig Connection to RAX200
Hello, I am not sure which connection I need to make on the back of my RAX200 in order to use the 2.5Gbps from the modem. Do I connect the modem to the multi-gig port on the back of the RAX200 o...
- Apr 12, 2021
Please mark your thread as solved so others will know.
Enjoy, :smileywink:
CAmbr52342 wrote:
Thank you! It works.
Apr 11, 2021Guru - Experienced User
If the cm2050v is already activated, then connect it to the multigig port on the back of the rax200. you'll need to change the wan port in the settings to the multigig port and reboot both devices after its been changed.
I've done it with my cm2000 on both my rax200 and my raxe500. works great.
CAmbr52342
Apr 12, 2021Tutor
- plemansApr 12, 2021Guru - Experienced User
glad to hear it!
- FURRYe38Apr 12, 2021Guru - Experienced User
Enjoy, :smileywink:
