CAmbr52342
Apr 11, 2021Tutor
CM2050V 2.5 Gbps Multi-Gig Connection to RAX200
Hello, I am not sure which connection I need to make on the back of my RAX200 in order to use the 2.5Gbps from the modem. Do I connect the modem to the multi-gig port on the back of the RAX200 o...
- Apr 12, 2021
Please mark your thread as solved so others will know.
Enjoy, :smileywink:
CAmbr52342 wrote:
Thank you! It works.
CAmbr52342
Apr 12, 2021Tutor
Apr 12, 2021Guru - Experienced User
glad to hear it!
