Lexxfyre
Oct 10, 2022Aspirant
Cm2050v disconnects from isp
My modem seems to be dropping the isp overnight. Has been happening every other night for about a week. I didn’t see any firmware updates. And all the cables attached are brand new. The router I have ...
Oct 10, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 or CAT6A STP is recommended.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- LexxfyreOct 20, 2022Aspirant
Connection Status
Startup Procedure Procedure Status Comment Acquire Downstream Channel 501000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 5 501000000 Hz 2.6 dBmV 42.1 dB 0 0 2 Locked QAM256 2 483000000 Hz 2.9 dBmV 42.1 dB 0 0 3 Locked QAM256 3 489000000 Hz 2.9 dBmV 42.1 dB 0 0 4 Locked QAM256 4 495000000 Hz 2.7 dBmV 42.1 dB 0 0 5 Locked QAM256 6 507000000 Hz 2.3 dBmV 42.0 dB 0 0 6 Locked QAM256 7 513000000 Hz 2.1 dBmV 41.9 dB 0 0 7 Locked QAM256 8 519000000 Hz 2.0 dBmV 41.8 dB 0 0 8 Locked QAM256 9 525000000 Hz 2.0 dBmV 41.8 dB 0 0 9 Locked QAM256 10 531000000 Hz 1.9 dBmV 41.7 dB 0 0 10 Locked QAM256 11 537000000 Hz 1.6 dBmV 41.5 dB 0 0 11 Locked QAM256 12 543000000 Hz 1.5 dBmV 41.4 dB 0 0 12 Locked QAM256 13 555000000 Hz 1.4 dBmV 41.3 dB 0 0 13 Locked QAM256 14 561000000 Hz 1.2 dBmV 41.3 dB 0 0 14 Locked QAM256 15 567000000 Hz 0.9 dBmV 40.8 dB 0 0 15 Locked QAM256 16 573000000 Hz 0.5 dBmV 40.9 dB 0 0 16 Locked QAM256 17 579000000 Hz 0.2 dBmV 40.9 dB 0 0 17 Locked QAM256 18 585000000 Hz 0.2 dBmV 40.9 dB 0 0 18 Locked QAM256 19 591000000 Hz 0.1 dBmV 40.8 dB 0 0 19 Locked QAM256 20 597000000 Hz 0.3 dBmV 40.8 dB 0 0 20 Locked QAM256 21 603000000 Hz 0.1 dBmV 40.7 dB 0 0 21 Locked QAM256 22 609000000 Hz -0.3 dBmV 40.6 dB 0 0 22 Locked QAM256 23 615000000 Hz -1.1 dBmV 40.3 dB 0 0 23 Locked QAM256 24 621000000 Hz -1.1 dBmV 40.2 dB 0 0 24 Locked QAM256 25 627000000 Hz -0.9 dBmV 40.3 dB 0 0 25 Locked QAM256 26 633000000 Hz 0.0 dBmV 40.6 dB 0 0 26 Locked QAM256 27 639000000 Hz 0.4 dBmV 40.7 dB 0 0 27 Locked QAM256 28 645000000 Hz 0.9 dBmV 41.0 dB 0 0 28 Locked QAM256 29 651000000 Hz 1.0 dBmV 41.0 dB 0 0 29 Locked QAM256 30 657000000 Hz 1.4 dBmV 41.2 dB 0 0 30 Locked QAM256 32 663000000 Hz 1.7 dBmV 41.3 dB 0 0 31 Locked QAM256 33 669000000 Hz 1.6 dBmV 41.0 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 35600000 Hz 47.0 dBmV 2 Locked ATDMA 2 5120 29200000 Hz 47.5 dBmV 3 Locked ATDMA 3 5120 22800000 Hz 47.5 dBmV 4 Locked ATDMA 4 5120 16400000 Hz 46.8 dBmV 5 Locked ATDMA 5 1280 39600000 Hz 47.5 dBmV 6 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock Status Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 31 690000000 Hz 2.1 dBmV 40.4 dB 1108 ~ 2987 62820135 61179393 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Current System Time:Thu Oct 20 16:50:38 2022 System Up Time:00:46:15 - LexxfyreOct 20, 2022Aspirant
Event Log
Thu Oct 20 16:05:26 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 16:05:12 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 16:05:08 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6 Time Not Established (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 15:57:08 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 15:56:52 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 15:56:48 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6 Time Not Established (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 13:00:55 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 13:00:45 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:51:27 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:50:59 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:50:45 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:43:06 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:40:31 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:40:19 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:40:03 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:39:58 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6 Time Not Established (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:38:25 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:38:10 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 4; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:37:51 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:37:34 2022 (Warning (5)) MDD message timeout;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:37:28 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 23; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:37:16 2022 (Warning (5)) MDD message timeout;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:37:15 2022 (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:37:12 2022 (Warning (5)) MDD message timeout;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:37:12 2022 (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:35:05 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:34:39 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:34:25 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:33:43 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:31:14 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; Thu Oct 20 12:30:13 2022 (Notice (6)) CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Oct 20, 2022Guru - Experienced User
Power looks ok but some channels are not the same as the others.
You have lots of criticals that the ISP needs to review and resolve.- LexxfyreOct 20, 2022Aspirant
So action is needed from the ISP to resolve? Is there anything I should mention to them specifically to get help with this issue?
