Lexxfyre
Oct 10, 2022Aspirant
Cm2050v disconnects from isp
My modem seems to be dropping the isp overnight. Has been happening every other night for about a week. I didn’t see any firmware updates. And all the cables attached are brand new. The router I have ...
Oct 10, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 or CAT6A STP is recommended.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Lexxfyre
Oct 20, 2022Aspirant
Event Log
| Thu Oct 20 16:05:26 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 16:05:12 2022 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 16:05:08 2022 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv6 |
| Time Not Established | (Critical (3)) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 15:57:08 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 15:56:52 2022 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 15:56:48 2022 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 13:00:55 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 13:00:45 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:51:27 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:50:59 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:50:45 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:43:06 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:40:31 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:40:19 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:40:03 2022 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:39:58 2022 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:38:25 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:38:10 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 4; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:37:51 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 22; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:37:34 2022 | (Warning (5)) | MDD message timeout;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:37:28 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 23; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:37:16 2022 | (Warning (5)) | MDD message timeout;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:37:15 2022 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:37:12 2022 | (Warning (5)) | MDD message timeout;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:37:12 2022 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:35:05 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:34:39 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:34:25 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:33:43 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:31:14 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
| Thu Oct 20 12:30:13 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 16; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:3b:76:40;CMTS-MAC=00:01:5c:82:be:4e;CM-QOS=1.1;CM-VER=3.1; |
- FURRYe38Oct 20, 2022Guru - Experienced User
Power looks ok but some channels are not the same as the others.
You have lots of criticals that the ISP needs to review and resolve.
