Mdunn1331
Oct 11, 2022Aspirant
CM2050v doesn't work with home wall jack
I've recently purchased a cm2050v to replace my xfinity xFi modem router combo. Unfortunately, it seems as though the modem doesn't work with the rest of my home. When connected directly to the modem,...
Oct 11, 2022Guru - Experienced User
You'll need to check the phone cabling in the home to make sure the cabling is working and configured right. If the phone works directly connected to the modem, then the problem is elsewhere.
