katlou
Jun 09, 2024Aspirant
CM2050V firmware update
I am wondering if there is still a plan to update the firmware for the CM2050V modem problem or is this something that is no longer in the works? I purchased this modem months ago specifically for t...
Jun 09, 2024Guru - Experienced User
Would be something to contact the ISP about. Voice has been supported on this model modem since it first came out. If there is a problem, the ISP would be to send out a tech and have them help you with getting that working.
