katlou
Jun 09, 2024Aspirant
CM2050V firmware update
I am wondering if there is still a plan to update the firmware for the CM2050V modem problem or is this something that is no longer in the works? I purchased this modem months ago specifically for t...
katlou
Jun 14, 2024Aspirant
The phone might work with this modem but there is the other issue with the modem that Netgear is supposedly working on that also needs to be fixed. It has been months since this other issue started. I don't want to transfer my phone service to Xfinity (my ISP) until this other issue is corrected because I might need to change to a different modem. In addition to that I think there is only one other modem with voice that Xfinity approves and based on reviews I have read this other modem also has major issues. I just want Netgear to give us an update about if the other issue with the CM2050v is going to be fixed or if they have given up on it. Thanks for your help.
Jun 14, 2024Guru - Experienced User
What other issue are you referring too?
- katlouJun 14, 2024Aspirant
I don't really know how to describe it but it seems to have to do with speed. My upstream light on the modem has been amber since I purchased it and it show critical errors when I look at the logs. I was about to have Xfinity out to look at the problem but then the firmware was updated in October 2023 which corrected this on my modem (at least all the lights were now white) but it caused disconnection problems for other people so they rolled back the firmware to the old version I think in December. Netgear has from what I have read been working on a firmware fix ever since but I haven't seen any information for months about if they plan to continue working on this. I am getting ready to purchase a new modem if we don't get an update soon. This may only be a problem for some Xfinity customers.
- FURRYe38Jun 14, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- NJGungadinJun 17, 2024Aspirant
I installed the same cable modem because I have Xfinity triple play. I have not had the problems you are experiencing. The phone work fine. Actually, I don't ever use the phone but send spam calls to it. The mail box is kept full. In case you cannot get the modem to work correctly, think about moving you number to a mobile phone for the minimum monthly charges. Incoming calls are free typically and if you use Wi-Fi calling outgoing is free too. Triple play becomes expensive after the honeymoon period is over.
