katlou
Jun 09, 2024Aspirant
CM2050V firmware update
I am wondering if there is still a plan to update the firmware for the CM2050V modem problem or is this something that is no longer in the works? I purchased this modem months ago specifically for t...
Jun 17, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
katlou wrote:
Thank you for your suggestion, NJGungadin about moving my number to a mobile phone. I do have a mobile phone in addition to the landline but I want to keep my landline too. I am just waiting for Netgear to give a response as to when/if they are going to have the new firmware update that is supposed to take care of the issue that some Netgear CM2050v customers are having.
Dinger19
Jul 03, 2024Initiate
Believe what OP is referring to is the Comcast/XFINITY issue regarding compatibility with ISP's "enhanced speed" plans (mid-split setup). You may recall that the CM2050V was on ISP list as a compatible, and recommended, cable/voice modem option suitable for higher upstream speeds in areas "upgraded" by Comcast/XFINITY. However the firmware update pushed out which allowed access to higher upstream speeds (V09.01.01) created significant stability issues for many other owners. The FW for Comcast/XFINITY was then rolled back to older version V02.01.03 which removed the "access" to the higher upstream speeds.
In my limited contacts with each company, both Netgear and Comcast have pointed fingers at each other and though an earlier response to someone else on the topic made it sound like a FW update was being worked on by Netgear "with highest priority", the topic has gone completely silent on both Netgear and Comcast ends, leaving many owners $300 out of pocket for a modem that likely provides no discernible benefit over previous cable/voice modem.
So...voice works and the cable modem works, but only to access standard speeds and not to access the "enhanced speeds". Neither Netgear nor Comcast are providing any updates and most threads seem to be closed down, and Comcast continues to push customers to "rent an Xfinity gateway" which most purchasers do not wish to do in the first place.
