Merlin152
Dec 11, 2022Follower
CM2050V looking for the optimum cable version
I purchased the CM2050V and found out it works only with Xfinity! I have Optimum cable and need to find the comparable one for that cable system.
Dec 12, 2022Guru - Experienced User
You'd have to check with optimum on what devices they support that have matching capability. Many of the ones that support voice require a certain device to be used.
