hophead44
Aug 18, 2021Guide
CM2050V Provision Status stuck in: Establishing Security
I had a netgear cable modem with xfinity that had voice and initernet. It worked fine and I just upgraded the cable modem and contacted xfinity support to provistion it. Internet access is working gr...
- Sep 17, 2021
FYI...was able to get this resolved. There was a certain tech team that needed to set the modem up. Although I had gone through the setup previously, and my internet was working fine, the phone side had not been set to the new modem. It was a painful journey working through online chats and being transferred, but once I got connected to the right person it took less than 5 minutes.
Aug 25, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- hophead44Aug 25, 2021Guide
Thank you for the reply. The only think I haven't done is turned it off for >1 minute. I'll try that.
- clarkyfunSep 02, 2021Initiate
Do you have an upate? I have the same issue.
- FURRYe38Sep 02, 2021Guru - Experienced User
Any progress on this?
- hophead44Sep 02, 2021Guide
To Update:
No progress. The 1 minute full power cycle didn't help. I tried everything else.
I'm pretty sure that the issue is on xfinity/comcast side. Perhaps the setup they are sending do the modem but that is a total guess. I'm going to try 1 more time with xfinity. After that I'm going to discontinue the phone service with them. Long story and I've had many problems with their support online but that is not something for this forum.
I will update here when I try 1 last time. I will need maybe a free 4 hour block free to be on the phone with them as they escalate. No slam intended. That is how long it has sometimes taken me in the past. I just haven't had the free 4 hour block.
