bobkoz
Nov 22, 2024Aspirant
CM2050v Slow Upload Speed, #CM2050V
It’s been almost a year since I bought my Netgear #CM2050V modem to use with my Comcast service. The modem NEVER delivered the upload speed I’m paying for. Comcast promised a firmware update that it ...
Nov 23, 2024Guru - Experienced User
What speed are you paying for?
The ISP is in charge of supporting modems on there network and supporting them on either there standard tier speeds or there next generation speeds. NG only gives the ISP FW to test and then certify for use on the ISP network. It's up to the ISP to make that happen.
You'll need to wait fo the ISP and NG to get the CM2050v to support the higher speeds. ISP isn't supporting the CM2050v on there next gen speed tier as of yet:
