bobkoz
Nov 22, 2024Aspirant
CM2050v Slow Upload Speed, #CM2050V
It’s been almost a year since I bought my Netgear #CM2050V modem to use with my Comcast service. The modem NEVER delivered the upload speed I’m paying for. Comcast promised a firmware update that it ...
bobkoz
Nov 25, 2024Aspirant
The CM2050V has appeared on approved equipment lists since early this year. Comcast says that they are having difficulty getting the CM2050V to work with their network, and are still working on the speed issue. Doesn't Netgear work with cable providers when it releases equipment?
I won't be buying Netgear equipment going forward.
- FURRYe38Nov 25, 2024Guru - Experienced User
Yes. And it's up to the ISP to get the Cm modem working and tested and certified on there system. Does work with NG as needed I presume. Doesn't happen over night and problems may be seen by the ISP that cause problems down the line. ISP serivces are complex systems. May effect other Mfrs as well. So to blame NG would be incorrect or claim to avoid NG would be invalid. But your choice good luck.
