rickpinette67
Dec 17, 2023Aspirant
CM2050V speed problems
I've seen several posts in here about speed problems with their nighthawk. Motum, I'm experienced in the same. I was getting my speeds at 1 point, but now the speeds have dropped. I'm paying for 1.2GB...
rickpinette67
So here is the config. see anything unusual?
Dec 17, 2023Guru - Experienced User
Power levels are on the lower side but with in specs.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Correctables and un-correctables are zeros which is good.
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the brand and model of the host wifi router connected to the modem?
- rickpinette67Dec 18, 2023Aspirant
Sorry forgot to post Router, it's a ASUS ROG Rapture GT-AXE1600 Quad-band wifi 6E. I'm sure you know the specs.
