rickpinette67
Dec 17, 2023Aspirant
CM2050V speed problems
I've seen several posts in here about speed problems with their nighthawk. Motum, I'm experienced in the same. I was getting my speeds at 1 point, but now the speeds have dropped. I'm paying for 1.2GB...
rickpinette67
Dec 18, 2023Aspirant
Kitsap,
Thanks for responding, it doesn't really effect what I use my network for but more the principle. If I pay for heated seats in my truck and they didn't work then the principle remains the same, I'm paying for it therefore I should get the product as described. So as I stated in my initial post, I was locked out since then installed my service and called a couple times most recent as Sunday night telling them I cannot get into my modem. Woke up this morning and coincidently, I could get into my modem. So I will just wait it out, not the end of the work. With my new ASUS ROG Rapture AXE1600, I'm getting download speeds of 1.423Gbs on wifi 6, so there's that
Dec 18, 2023Guru - Experienced User
Post those event logs please...
- rickpinette67Dec 18, 2023Aspirant
Furry, will do when I get home from work
- rickpinette67Dec 19, 2023Aspirant
So so logs to be found it appears they were cleared and not by me, I find this a bit strange
- FURRYe38Dec 19, 2023Guru - Experienced User
So if you go in and select the Cable Connections Diagnostic button, this should save off both current state of the cable connections and the event logs to a file...
