rickpinette67
Dec 17, 2023Aspirant
CM2050V speed problems
I've seen several posts in here about speed problems with their nighthawk. Motum, I'm experienced in the same. I was getting my speeds at 1 point, but now the speeds have dropped. I'm paying for 1.2GB...
Dec 18, 2023Guru - Experienced User
Post those event logs please...
rickpinette67
Dec 18, 2023Aspirant
Furry, will do when I get home from work
- rickpinette67Dec 19, 2023Aspirant
So so logs to be found it appears they were cleared and not by me, I find this a bit strange
- FURRYe38Dec 19, 2023Guru - Experienced User
So if you go in and select the Cable Connections Diagnostic button, this should save off both current state of the cable connections and the event logs to a file...
- KitsapDec 19, 2023Master
FURRYe38 wrote:So if you go in and select the Cable Connections Diagnostic button, this should save off both current state of the cable connections and the event logs to a file...
The Cable Connections Diagnostic button went away when the firmware was reverted back to V2.01.03.
Cut and paste the data into a word processing file, save as a pdf before attaching it to the message reply.
