Ryan-F
Feb 26, 2023Aspirant
CM2050V Spotty internet connection
Hi everyone, I replaced my XB7 with a CM2050V about 20 days ago. Ever since then the internet has been highly unreliable. All power levels are within spec and SNR is above 45db. There are no errors e...
Feb 26, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Ryan-F
Event Log:
| Sun Feb 26 13:14:26 2023 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 1; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:14:17 2023 | (Warning (5)) | MDD message timeout;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:14:13 2023 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:14:01 2023 | (Critical (3)) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:55 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:55 2023 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:53 2023 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:45 2023 | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv6 |
| Sun Feb 26 13:13:37 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:35 2023 | (Warning (5)) | Lost MDD Timeout;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:28 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:27 2023 | (Warning (5)) | Lost MDD Timeout;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:20 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:13:11 2023 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv6 |
| Time Not Established | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:09:17 2023 | (Critical (3)) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:09:17 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:09:13 2023 | (Critical (3)) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:09:13 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:08:29 2023 | (Warning (5)) | MDD message timeout;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:08:29 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:08:23 2023 | (Warning (5)) | MDD message timeout;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:08:22 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:05:56 2023 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:05:55 2023 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 1; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:05:39 2023 | (Warning (5)) | MDD message timeout;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:05:21 2023 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:05:20 2023 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:05:11 2023 | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv6 |
| Sun Feb 26 13:05:02 2023 | (Warning (5)) | Lost MDD Timeout;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:04:53 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:03:53 2023 | (Critical (3)) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:03:53 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:03:49 2023 | (Critical (3)) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:03:49 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:03:48 2023 | (Critical (3)) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:03:48 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:03:45 2023 | (Critical (3)) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
| Sun Feb 26 13:03:45 2023 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b4:7b:c0;CMTS-MAC=00:90:f0:6f:08:00;CM-QOS=1.1;CM-VER=3.1; |
- FURRYe38Feb 26, 2023Guru - Experienced User
I see lots of Criticals in the events log that the ISP needs to review and resolve.
Lets take a look at the cable connections page please...
- Ryan-FFeb 26, 2023Aspirant
I do not know why the connections post keeps disappearing on me. I've posted it 3 times now.
Put it in a PDF file then attach it using the Choose File button on your next post.
Sorry to use pastebin but the connections post keeps deleting: https://pastebin.com/ychzHBip
