Ryan-F
Feb 26, 2023Aspirant
CM2050V Spotty internet connection
Hi everyone, I replaced my XB7 with a CM2050V about 20 days ago. Ever since then the internet has been highly unreliable. All power levels are within spec and SNR is above 45db. There are no errors e...
Ryan-F
I'll check all of those things and contact Xfinity again to get the modem provisioned, thank you!
Feb 26, 2023Guru - Experienced User
Another thing you can try is run www.pingplotter.com with a wired PC connected to the modem with out the Linksys, then with the Linksys in line.
