Rjeter
Aug 26, 2023Aspirant
CM2050V Stopped working
Hi y’all, I’m having the same issue with CM2050V. Stopped working. All lights flicker and won’t respond to anything nor factory reset. Switched back to old 1150V modem and it works fine, so I know th...
Kitsap
Aug 28, 2023Master
Rjeter wrote:Hi y’all, I’m having the same issue with CM2050V. Stopped working. All lights flicker and won’t respond to anything nor factory reset. Switched back to old 1150V modem and it works fine, so I know the CM2050v is the problem. 13months from purchase so mynetgear won’t let me contact support or open a case; it just points me back to community and knowledge base articles that don’t cover this issue. Any advice from others on how this was resolved?
Make sure the voltage and amp outputs on your power adapter match up to the requirements marked on the modem.
Make sure your power adapter is plugged in to a working outlet. Maybe try a different one for test. Maybe try a different power adapter.
Have you tried the factory reset with the coax connected and with the coax disconnected?
