Seebear
Dec 28, 2022Initiate
CM2050V XFinity Activation Issue
XFinity emailed me and told me that the modem I was using didn't fully support my internet speed, they gave me a list of modems that would and I selected the CM2050V. I put it in place of my old mod...
- Dec 29, 2022
Seebear wrote:Thanks for the suggestions. I plugged it back in, ran the XFinitiy activation on it again so I could try the suggestions and get the information from it, but this time it came right up and worked fine, so I think the issue may have been with XFinity's provisioning last night. Thank you all for your advice.
Glad you got it working. I have had my C2050V in service for 16+ months and it has been a solid performer.
Recommend you mark this thread as resolved so others can benefit from your experience.
Dec 28, 2022Guru - Experienced User
What speed up and down are you paying for?
The CM supports up to 2.5Gb speeds.
What FW is loaded on the modem?
Please post a copy and paste of the modems connection status and event log page when connected to isp line..
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Seebear
Dec 29, 2022Initiate
- KitsapDec 29, 2022Master
