mcsd4959
Feb 23, 2023Aspirant
CM2050V Xfinity cannot activate voice
After multiple calls with customer service, a tech came out today and still could not get voice to work. Internet is fine, but voice is a no-go. Tech called multiple people for assistance but no on...
Feb 23, 2023Guru - Experienced User
the emta log/connection screen would be better. did you have them reprovision it?
mcsd4959
Thanks - new screenshot attached. I think this is the one you asked for.
I'm not sure exactly what steps were taken but the tech did say he had Xfinity activate the modem repeatedly and nothing worked. He came up with the idea of using the old modem for voice and worked with Xfinity to make that work so it seemed to me that he knew what he was doing...but I am just a lay person.
- owlynFeb 23, 2023LuminaryThe regular tech support people can’t do it. You need to get through to the Xfinity Voice Support department.
- KitsapFeb 23, 2023Master
owlyn wrote:
The regular tech support people can’t do it. You need to get through to the Xfinity Voice Support department.Provisioning and activation of the modem is a separate event from provisioning and activation of the eMTA. When the technician asked to have the modem activated, they missed the mark. Standard support personnel do not have the tools to deal with the eMTA. Only the Xfinity Voice Support group has the tools.
