Doug-48051
Oct 15, 2021Luminary
CM2050V Xfinity Voice Activation
Reposted from General Forum I just purchased a Nighthawk 2050V Modem with Voice. This device is to replace my Xfinity Voice modem. The 2050V is a modem only, I am planing on using it with my Orbi...
- Oct 18, 2021
Xfinity has to configure and assign the device manually. But it works great now.
quagmire1
I have a CM2050V on Comcast, and it's fantastic*. I think you're going to be very happy with it.
To activate:
Assuming you have a computer with an Ethernet cable:
- Turn off your computer
- Turn off CM2050V (if it's not already off)
- Attach Comcast coax cable to CM2050V
- Attach Ethernet cable (minimum cat 5E) between PC and CM2050V
- Power up PC. If PC is not using the default Comcast DNS server, change settings so it it is. If you don't know what this means, you're almost certainly using the default DNS server.
- Power up CM2050V. Wait - the CM2050V may upgrade its firmware and reboot several times. The whole process could take up to 15 minutes. When all lights are lit solidly (except the Multi-Gig light, which should be flashing), proceed to next step.
- Go to any random web page. You should be put into Comcast's walled garden. Sign in with your Comcast userid and password. In a few seconds, you should get confirmation that your new modem has been activated.
- Power down PC.
- Power down CM2050V.
- Power down RBR850 (I think that's what you said you had in the other thread).
- Attach Ethernet cable between CM2050V and RBR850 WAN port
- Power up CM2050V. Wait until it's fully booted
- Power up RBR850. Multi-Gig light on CM2050V should turn blue to indicate 2.5Gbps connection.
- Power up your PC.
At this point, you should have working phone and Internet. It can take 24-48 hours for everything to get provisioned properly. For example, Xfinity Stream will probably think you're not on In-home Internet for a day or two. Don't panic, and don't call Comcast unless things really aren't working at all.
*Disclaimer: I was a beta tester for the CM2050V, and received my modem for free. Nevertheless, I think it's a top-notch modem, and I highly recommend it.
Edit: added step 3 - connect Coax cable to modem. I know that's obvious, but I just wanted to be complete.
- Doug-48051Oct 16, 2021Luminary
Thanks for the great write-up.
THE RESULT
Browers goes to Xfinity Activation page.
I verify account, then goes back to activation page..
Device is listed as offline by Xfinity,stating it must be in bridge mode.
We know the CM2050V does not have a bridge mode.
As much as I hate Xfinity Tech screwing with my network, they are scheduled to be here in 5 hours, wish me luck. I will keep everyone posted.
- FURRYe38Oct 16, 2021Guru - Experienced User
You need to get to someone ON the phone at XF and have them help you. These walled garden activation pages may not be working right.
- KitsapOct 16, 2021Master
Please confirm you followed step 4 in quagmire1 procedure?
After the modem has failed to activate completely a couple of times, have you done a full default reset before attempting the activation procedure again?
- Doug-48051Oct 18, 2021Luminary
