Doug-48051
Oct 15, 2021Luminary
CM2050V Xfinity Voice Activation
Reposted from General Forum I just purchased a Nighthawk 2050V Modem with Voice. This device is to replace my Xfinity Voice modem. The 2050V is a modem only, I am planing on using it with my Orbi...
- Oct 18, 2021
Xfinity has to configure and assign the device manually. But it works great now.
Kitsap
Oct 16, 2021Master
Please confirm you followed step 4 in quagmire1 procedure?
After the modem has failed to activate completely a couple of times, have you done a full default reset before attempting the activation procedure again?
Doug-48051
Oct 18, 2021Luminary
- FURRYe38Oct 18, 2021Guru - Experienced User
Glad they are able to finally get it working.
Please mark your thread as solved so others will know.
Enjoy.
