OldPilot2
Jun 05, 2020Aspirant
CM2200 on 192.168.100.1
I just bought a CM1100 and am extremely annoyed to find that its IP address is fixed at 192.168.100.1. The network I am installing it on uses the 192.168.2.xxx subnet, which means that the cable mod...
Jun 06, 2020Guru - Experienced User
192.168.100.1 is a fixed address for a reason and can not be changed. Its the address of the modems web page for user access. The CM modem does NOT have a built in router. Its MODEM ONLY! You need to connect a wireless router to LAN port #1 if you want to connect more than just 1 devices to have internet access.
Be sure you contact your ISP to ensure the CM modem is fully supported and serviced by your ISP.
OldPilot2 wrote:I just bought a CM1100 and am extremely annoyed to find that its IP address is fixed at 192.168.100.1. The network I am installing it on uses the 192.168.2.xxx subnet, which means that the cable modem is not easily accessible for checking and management.
I am not interested in having the cable modem tail wag my network dog. I am not going to reconfigure my network to 1.92.168.100.xxx !
I have never had a problem like this before. I normally set suitable hard addresses to boxes as needed.
Is there a workaround for this stupidity? I have never seen it done but it seems like there could be a simple address translation box inserted between the network and the CM1100, making the modem happy and my network access easy.
Grrr ... Any ideas folks? This cannot be a new problem but Search was not helpful for me.
