ceddes
Dec 19, 2024Aspirant
CM3000 and EERO Pro 6E
I'm having issues getting my Eero to work with this modem. Is there a specific network setting I need to put the Eero in? I don't see any settings I can change on the CM3000 besides the port aggregat...
Dec 19, 2024Guru - Experienced User
The CM modem doesn't have a build in router so if you have the Eero in bridge mode, you'll need to change the Eero back to router mode. Something to contact the Eero mfr about regarding there product.
Power OFF the CM modem and Eero router for 1 minute then back on to ensure the CM modem gets the new MAC address from the Eero router.
Good Luck.
