ceddes
Dec 19, 2024Aspirant
CM3000 and EERO Pro 6E
I'm having issues getting my Eero to work with this modem. Is there a specific network setting I need to put the Eero in? I don't see any settings I can change on the CM3000 besides the port aggregat...
Dec 20, 2024Guru - Experienced User
Anytime you setup a new mode/system, starting over from factory is a good choice.
I'd reset the Eero back to factory, install the modem, the install the eero. As long as you keep the same ssid/password, devices should auto-connect back to the wifi. Tends to make system changes easier/faster.
