ibuyufo
Jan 20, 2026Star
CM3000 and only 1 & 2 are lit in the front panel
I found a CM3000 in the e-waste pile and wanted to know if it's possible to have it fixed rather than e-wasted. The front panel has no sign of power other than the numbers 1 & 2 lit up solid white.
- Jan 20, 2026
Looks like someone already tried to pry it open. I guess it'll go back to the e-waste. It's beyond what I know! Thanks everyone!
Jan 20, 2026Guru - Experienced User
Try and 30-30-30 reset on it and give about 2-3 minutes and with one ethernet PC connected to the port1 in back, see if you can access the modems web page at 192.168.100.1. If no, then ewaste. Shame.
