Victor1221's avatar
Victor1221
CM3000 Browser Issues
I am writing to report an issue with the cable connection site on Chromium-based browsers. While other functions of the site are functioning correctly, the loading time for the cable connection site ...
  • Victor1221's avatar
    Victor1221
    Apr 23, 2025
    It appears that the issue was caused by an extension, which is challenging to identify. The problem lies primarily on the development side of the extension I am using. Therefore, the issue has been resolved. Still find it ironic noone from netgear even responds to forums pretty disappointing just like the XR1000 that's been left to rust,
