Victor1221
Mar 08, 2025Aspirant
CM3000 Browser Issues
I am writing to report an issue with the cable connection site on Chromium-based browsers. While other functions of the site are functioning correctly, the loading time for the cable connection site ...
- Apr 23, 2025
It appears that the issue was caused by an extension, which is challenging to identify. The problem lies primarily on the development side of the extension I am using. Therefore, the issue has been resolved. Still find it ironic noone from netgear even responds to forums pretty disappointing just like the XR1000 that's been left to rust,
Victor1221
Mar 11, 2025Aspirant
During direct testing of the connection to the modem, I observed that it successfully loaded content more efficiently. However, this observation does not provide a definitive explanation for why the connection fails to load in certain browsers while functioning correctly in others when connected to the router. I have tested it using different DNS servers in case it was a DNS failure, but that doesn’t seem to be the case.
I am currently subscribed to the Comcast/Xfinity residential next-generation speed tier.
Victor1221
Apr 23, 2025Aspirant
- FURRYe38Apr 24, 2025Guru - Experienced User
We find that only when major issues appear do moderators come if for help and some information. Seems like this wasn't major and was not a NG issue.
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
